MACAuto »
https://forums.nicoclub.com/macauto-u107424.html
Thu Oct 02, 2008 1:29 pm
Sounds like you have bent or broken either the front lower control arm, or the tension rod. Also possible is damage to the tie rod or tie rod end. Check these components, and replace as needed (with better stuff if you are drifting), and watch out for the curbs. Heim jointed tension rods will give you much better turn-in feel, and are a bit stronger. Good tie rods and ends (like TEIN), will actually give you much better steering angle for drifting (you can also amaze your friends by doing a u-turn in about a 20 ft circle!)
My shop serves ALL of the drifters in Colorado, so we have seen the sad results of about every kind of curb hit. There is a huge selection of excellent suspension parts available for the s13/s14 chassis. Get in control.
MACAutoParker, CO
