I bought my N/A '91 300ZX last month. This week brought it to my mechanic for a transmission seal replacement and a tuneup. Picked it up Wednesday and have been driving it daily since. Late last night on my way home I took off from a stop and accelerated fairly strongly through first, second, hit third and got up to about 5,000 RPMs and the engine died - straight from 5K to 0, no chugging or anything. I coasted onto a side street and attempted to restart the car with no luck. The car turns over (cranks) but does not start. Also, when the engine died my aftermarket stereo head unit froze/shorted, so that even with the ignition in the off position the stereo display was on. I had to unplug the whole head unit to reset it. I don't know what this has to do with the problem, but it isn't normal.
What I've learned so far:
- My gas gauge put me below 1/8 tank, so I added 2 gallons of gas, just in case. No such luck.
- Cycled the ignition from OFF to RUN position multiple times and listened for fuel pump priming - last night my pump primed a few times intermittently, today not at all.
- Checked ECU codes) - it threw a 33 (left exhaust gas sensor), 34 (detonation sensor circuit) and 53 (right exhaust gas sensor). I didn't check codes before, so don't know if 34 is new, but from what I read it shouldn't kill the engine entirely.
- Googled "300zx no spark" and read Vilmenay's advice about diagnosing a no spark issue:
- Checked for spark by pulling a plug and grounding it against the intake manifold - no spark.
- Checked for power to the coil plug with a multimeter (need ignition in the RUN position for this) - there are 12 volts of power to the middle lead on the wire harness.
- Loosened the three bolts on the crank angle sensor (here's an image of a crank angle sensor on a 300zx for reference) and rotated it back and forth - not hearing injectors firing or fuel pump priming.
