diagnosing my clutch problem
s3xrapt0r
i just picked up a z32 clutch pedal is stuck to the floor i can pull it back up just fine by hand. just wondering if this would be the slave or master cyls ?? i never had a clutch issue like this before so what woudl be the best way to diagnose the issue ??
Modified by s3xrapt0r at 9:22 AM 1/3/2010
kpodj61240
Car: S14 Zenki
not trying to be rude but I typed in clutch pedal sticks to the floor on google and got a ton of results.....please search...
HOST
Car: 1993 300ZX N/A [SOLD] 1992 300ZX 2+2 [SOLD] 1992 300ZX N/A [TT Project]
s3xrapt0r wrote:i just picked up a z32 clutch pedal is stuck to the floor i can pull it back up just fine by hand. just wondering if this would be the slave or master cyls ?? i never had a clutch issue like this before so what woudl be the best way to diagnose the issue ??
Best case scenario, air in the lines or blown MC/SC.. when you replace the MC make sure you replace the SC at the same time. BUT you can replace the SC first because it is the easiest and cheapest. It's located near the transmission under the car. You'll have to jack it up to get to it, bleed after you replace it. If that doesn't help then it's the MC. If you replace both, bleed all known air out and it's still no good.. you need a new clutch my friend, worst case scenario.
s3xrapt0r
alright thank you yea i did use google and figured it was the cyls, but i was just hoping someone would post the locations. i was mad tired i rpaobly should have included that lol
HOST
s3xrapt0r wrote:alright thank you yea i did use google and figured it was the cyls, but i was just hoping someone would post the locations. i was mad tired i rpaobly should have included that lol
Well I Googled for the locations myself, couldn't find any pictures.. but they are easy to find. I told you where the slave is.. you can Google for a picture of a replacement slave and master so that you know what to look for when under the car and hood. That said, the MC is under the hood to the right behind the fuel filter on the firewall (standing at the front of the car). Right next to the brake master. It is a long metal tube looking type thing with a reservoir on it. Looks like the brake master but smaller. Hope this helps. If I had pics I would show you but I don't
