bcar240 »
https://forums.nicoclub.com/bcar240-u13477.html
Mon Sep 10, 2012 12:38 pm
I have an '86 z31 where both the instrument cluster and and climate control are doing very wonky things. The only part of the entire instrument panel/HVAC that consistently works properly is the tachometer and odometer displays. Here is a mostly comprehensive list of issues, I am sure many of them are related, but trying to figure out if there could be one root cause:
-The speedo occasionally switches on its own to km/h (both reading and units) and then quickly back to mph, also just recently the speedo started going to 0 for a few minutes then coming back (odos/mpg/accel don't work during this period)
-The three engine gauges flip out occasionally, the voltage reads top of scale, oil pressure reads 4 to 5 bars low, temp reads bottom of scale, even though everything is normal. They will eventually return to normal.
-Fuel gauge sometimes reads a random amount between the actual level and empty. The digit readout sometimes gets screwed up as well, but doesn't necessarily correspond to the bar graph. Ex. I have a 3/4 tank of fuel and the graph will show 1/4 tank and the digit says 1 gallon, or something like that.
-Average speed display doesn't work at all.
-The climate control functions correct as far as I can tell when it comes on (other than having no freon charge), but sometimes the control unit is just completely dead and unresponsive (no backlights, temp readouts blank, pressing buttons does nothing), the manual defrost DOES work but that's it. Then all of a sudden the whole thing will start working again.
All this stuff happens sporadically and comes and goes. It can happen together or as individual problems. Sometimes everything works 100%. It also seems to be affected by temperature. For example, the speedo acts up in the 80°s, engine instruments usually work fine above 80° or so, HVAC tends to act up more when cold, etc... I have done a lot of research and found that there are a lot of problems with the power supply unit for the dash, and there is a guy out there that refurbs them. Does this power both the dash and HVAC? I am not really sure where to start since nothing seems to be working consistently. When I bought the car about a year ago it did not have these issues. They started slowly until now they happen pretty much on every drive. Any help appreciated!
