BEST1TUNING.COM wrote:Do you have any Idea what the tune actually is set for? 5,000 is right around peak VE for a CA, that is where the motor takes in the best charge of air as long as you are fully spooled by then. It is also the point that requires the most fuel and if the tune is lacking fuel in this area you will get the lean misfire.
No I do not know what the tune is --bought off another member a few years ago shortly after installing the motor.
As for the 5000 RPM thing --it has not happened before at the track --and was fine this past weekend at an autoX. (1st and 2nd gear only)
I think I will add the fuel pump to the FPR and a new filter. Then I am going to have my buddy fab an intake pipe and upgrade the MAF and injectors. I picked up another ECU for this purpose but have been lazy about getting things done ( I hate it when work takes over my life)
Thanks for the input guys!
