jasonsos »
https://forums.nicoclub.com/jasonsos-u49059.html
Fri Nov 23, 2007 9:10 pm
Thanks Littlewillie, you may be right, although, consider this:we had a district temp drop on Thursday, and now my electric door locks won't lock when I push the remote button to lock and secure the car, but the doors DO LOCK once the engine is started. I must, however, manually lock the driver's door when parked and leaving the car.I think that the battery, about 4 years old, may be going bad in amperes as a result. This could be brought about by the cold weather, of course. This could also be the cause of the sunroof acting up, although I will try the white lithium lube as was suggested by our other member. If that, too, fails, then I am pretty sure that it is the battery. I shiver to think that the motor is going bad as you mentioned. That's likely a high price tag item to repair, certainly at a dealership.I'll keep everyone posted, as you, too, may have this problem one day.Thanks to all.Jasonsos
