Detonation Sensor
FullaBullz
Car: 1993 Nissan 300zx Twin Turbo, 2006 Nissan Xterra Offroad
I replaced my detonation sensor recently while the AT was out of the car. Problem is I made a “bone head” move and cut the clip off the ECU side of the wiring harness to wire in a resistor as a short-tem fix a while back. Well, I need to know which way the wires go from the ECU to the detonation sensor harness... and NO the colors don't match. The dealer wasn’t much help either. I have a 50/50 chance of getting it right but the plugs are not cheap. Could some one take a picture or tell me which colors go with which wire?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
if it's like the L6 it doesn't matter, I'd chance it but I am a dork
Vilmenay
Do you recall which resistor you used to do a temporary fix for the detanation sensor? what was the ohm and wattage on it.
Canyoncarver
Car: '93 300zx
There is only one wire from the ecu to the connector. The other wire is a ground. The ground wire should be pretty easy to determine. On the sensor, one connector pin wire should go into the sensor. The other connector pin is a shielded ground.
http://www.300zx.co.uk/cgi-bin...l=190
