under the intake manifold between cylinders 2 and 3. Its big and green. You can't miss it. Although its a pain in the *** to remove!Ca_Silvia wrote:Ok, so im going to replace the knock sensor anyways as a possible problem, but where abouts on the motor is it located? I know its a noob question but im not paying for some dumbass to do a potentialy 10 minute job for me.
Both because of where it's located. If your engine was pulled..it'd be a breeze.Ca_Silvia wrote:What do you mean, is it a prick to get at or is it just hard to pull off?
I drive a Silvia so, no swap herefloat_6969 wrote:Are you sure that the sensor is bad? Are you sure that it's wired up? They are quite frequently NOT wired up when the swap is done, which would cause the fault code.
