Kansei240sx »
https://forums.nicoclub.com/kansei240sx-u21658.html
Fri Oct 19, 2007 8:04 pm
Hey guys, i usually don't create threads to answer my questions, but im getting kinda stumped here, and i think im on the right path, but i want to know what everyone else's opinions are.
Heres are the mods that i think could contribute to my problems, but not all of them. RB25DETAVC-RSAFC-2Zietronix Wideband Tuned to a stable 11.9 afrStock Fuel pressure regulatorFMICSARD R2D2 Unrecirculated370cc injectorsBrand spankin new NGK Iridium Heat range 6 plugsWalbro 225 LHP 300ZX TT Fuel Filter
Ok, the other week i was having no problems. I would get up to around 12 psi or so and anything past that it would backfire/pop in the exhaust, i looked at the wideband and my AFR's are rich when this happens, im not leaning out,
Now its worse than ever, if my car hits around 10 psi or even gets above 8 or so, its cracks and backfires in the exhaust like crazy.
I thought i had a bad electrical connection, WHICH i did, so i fixed it with a new junction box. I took it for a spin, and took off from around 3500 rpms and the wheels broke loose and rpms shot up to redline and a loud audible backfire from the BEE-R rev limiter which was normal. So i was like... ok cool. So i get to an onramp and do the same thing, except a more stable load with no slipping of tires. Boost would climb up to around .67-69 bar and then if it went higher it would backfire, so i'd let off the throttle and then it would stop and the car would continue to haul *** to redline.
Heres reasons i think this is happening.
Detonation due to running 91 octaneNot high enough fuel pressure due to running stock FPR I dont think it is boost leaks because even with the vent to atmospheric bov, before i had the AFC, my RB would never and has never stalled or bucked from it and or boost leaks. NEVER. It would always run under par with boost leaks or a BOV leak never any kind of popping/backfiring/bucking/hesitation.
Any help would be great, thanks guys.
