Detonation/Ping
Khronik
Car: Pearl White - 91 N/A 2+2 Auto (RIP)
Arctic White - 96 N/A 2+0 5spd (SOLD)
Aztec Red - 90 TT 2+0 5spd (DD)
- Megan Racing DP's
- Borla Catback exhaust
- CZP ECU Upgrade
- SZ High 5 Clutch
Im getting a detonation sometimes when around 3700rpms or im guessing its a detonation? (pop/backfire sound)
this only usually happens in 1st gear, if/when it happens it does not always make the sound
that should mean my knock sensors are working since it doesnt happen at low rpms right?
would I then turn to ignition timing?
she has Injen Intake and Catback Exhaust doubt that would require a ECU tuning?
or am I on the wrong track of what this sound is
es.biggs
Car: 1990 300ZX 5sp NA
Yeah, I would def check your ignition timing.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
detonation sounds liek marbles in your exhaust and your ecu would correct for it anyhow, stock n/a that shouldn't be an issue
it's never a bad idea to check the ignition timing but i suspect you have a rich condition causing excessive fuel to burn in the exhaust
and no a cai does nto necesitate an ecu retune
Khronik
- Megan Racing DP's
- CZP ECU Upgrade
- SZ High 5 Clutch
hmm where would suggest to start?
also the past day or so sumtimes when starting the car i hear an electric whine? coming from right behind the drivers seat (fuel pump?) would a faulty fuel pump cause this?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
O2 sensors would cause a rich condition.
