he isnt detonating, its misfiring. his coil casings are cracked.cdorhout wrote:How much boost are you running? After upgrading turbo and turning boost up to 18-19psi, I was getting bad detonation.
I had to retard timing a few degrees at WOT.
Disregard if you're running stock turbo at 12psi. Detonation is probably not it unless you don't have enough fuel.
