Spectre23 »
https://forums.nicoclub.com/spectre23-u11197.html
Mon Feb 02, 2004 5:33 am
I did aa search and found my answer IF I had a '91+...
But on and '89-90 there doesn't appear to be a knock sensor. So I was putting my CA in last night and found the lower (Engine Harness #2 in FSM) harness wouldn't work. So I was going to use my lower harness from my front clip since it has the right connectors for the transmission and such. However, where the lower harness plugs into the main harness there is 4 plugs. 3 of them are just like the US. But the 4th one, the one under the fuse box, is different. The US harness has 4 wires, and the JDM one is 2 wires (black and white) for the knock sensor.
So where does the knock sensor get wired in on the '89-90 harness?? And what does the 4 wire plug get signal from on the US harness?? This last question I am sure would be answered with the right FSM, but unfortunately, the FSM I have is for a '91+. So does anyone know where I can get a '89-90 FSM online? At least the Electrical chapter? Did the '89-90 even have a knock sensor? I don't remember unplugging one. Was I right in using the JDM lower harness? The transmission plugs appear to be different and it has the knock sensor wire on it.
Thanks for the help guys. Hoping to have this running this weekend. Engine is in, now it is just down to plumbing and electrical.
