C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon Apr 05, 2004 8:41 pm
That's not detonation. Detonation sounds like ball bearings being flung around in your combustion chamber. What you are hearing is likely unburned fuel igniting when it hits air. You won't see detonation on a wideband. You can only see a condition that might cause a condition where detonation can likely occur(rean mixture). But even with a rich mixture, things like timing that is too far advanced, high compression, heat, and/or low octane fuel can cause detonation. When decelerating, you do not need a rich mixture. There is less load there and peak pressures will be much lower than under boost. Under cruising, and deceleration, you can run leaner mixtures. The reason you run richer mixtures under boost is to use the atomization of fuel to reduce the temperature of the air. Like water, fuel absorbs heat when it evaporates. And reducing charge temps will reduce the chance of detonation.
