baseballguru44 »
https://forums.nicoclub.com/baseballguru44-u292224.html
Tue Sep 24, 2019 6:09 pm
Hey y'all, figured I'd throw this out here and see if I could get any leads. 1985 720 King Cab 4x4 with carb Z24, 5-speed manual. Engine and carb were rebuilt around three years ago by previous owner.
When driving in any gear, if you give it a good amount of gas on an incline or floor it while flat, you'll get varying amounts of knocking/pinging/detonating/static, whatever you want to call it, coming from up front. Only happens when giving it gas. Sometimes it doesn't do it at all, but if you're in 5th gear on a slight incline at 2400-3000 RPM, it is pretty bad. It will disappear most of the time once you hit a certain RPM, around 3200-3400 I'd say.
I've done standard tune-up stuff, cap, rotor, plugs, wires, all good. I've read up a bit on detonation. Could be timing, compression, or something as simple as the gas, plugs, or lugging the motor.
Any tips would be great!
