mrmarbles »
https://forums.nicoclub.com/mrmarbles-u77020.html
Tue Oct 27, 2009 5:45 pm
So I just snagged these new wheels from a local forum for super cheap. After a quick test fit (After I already bought them) they wheels poke out about an inch or so front and back.
I have some JIC Magic coils and some RUCA's, so I've already dumped the car on stock SE's. I don't know if I can make these fit or not. I can post a picture later if needed.
Is it possible to make this fit at all, with a roll, pull, and camber? Or will I need overfenders? If anyone has had the same issues let me know what you did, and how you got this wheel to fit!
15x8 offset unknown.
So I figured I'd do some measuring and math.
From the face that of the bolt pattern that to the hub to the inside of the wheel is 3 inches. From the same face to the outside lip is 6 inches. Taking into account that the wheel size is actually from tire placement to tire placement, not lip to lip, the measurements should actually be 2.5 inches, and 5.5 inches, to make it an 8 inch wheel.
converted to millimeters, thats 203.2 mm wide, 63.5 mm to the inside, and139.7 mm to the outside.
With those measurements, that means I have a *NEGATIVE* 38.1 mm offset.
If offset were zero... (203.2/2 = 101.6) Actual measurements...(101.6 - 63.5 = 38.1)and (139.7 - 101.6 = 38.1)
Does this even make sense? I was told the wheel was an American Racing wheel. It is 15x8. Who makes a 15x8 -38 wheel?
