the overhual kit is OEM Nissan R32 gasket kitthe metal head gasket is Trust good call on the ARP rob bolts I also forgot about Thermostat002-M-P wrote:nice list, but I would like to know where you are getting some of these and/or what brand...
the rebuild gasket kit for $155...is that OEM gasket setthe metal head gasket for $120...what brand
it also wouldn't be a bad idea to add ARP rod bolts to the list if you are looking for upwards of 600hp...just an idea
I agree about emanage ultimate..I have it on the Z right now....Just get a Power FC D-Jetro from Nengun for $690 shipped....much better.Carl H wrote:bleh to emanage ultimate, and bleaaach to map.a list like that proves its not cheap to do a rb26 swap...least one thats done right.
I knew I would received all this criticism, Actual most all the prices (except est. ones) are confirmed pricing if you don't believe Im not loosing any sleep over it. I didn't include all of the work Im having done at a local shop the rewielding of the greddy FMIC kit along with the downpipe. I didn't have enough time at work to list other misc. items like bluefire did, And I paid only 3200.00 shipped to my door for rb26 complete motor/transmission.( still have receipt ) If I'm not mistaken rb26 transmission bell housing will do just fine. 002-M-P gave up my secret supplier for dirt cheap OEM parts. only thing I was off a little was head gasket I thought I had it saved as 125.00 but I was wrong.002-M-P wrote:I too think some of the parts are a little underpriced (or at least don't include est. shipping)...but they aren't way off.
My rb26 motor, that came with rb25 transmission, oil pan, clutch/flywheel, starter...cost me 5400 shippedI paid 250 shipped for my oem gasket kitIdler pulley and tensioner prices are correct from http://www.nismoparts.comI am going to modify the rb26 stock pan...extra oil capacity and upgraded oil baffle options
Also, what is wrong with the walbro 255 fuel pump? I have run it for 40k miles in my greddy tt 350z at 465whp (~550bhp) and have had 0 issues with it. The walbro should be good for nearly 650bhp. Sure its not the best out there, but it will work reliably for a cheaper option. Any more than 600bhp and I would be getting iffy with it though.
Could you explain why you dislike the EU? Have you personally had a bad experiance with it? Enlighten us please.Carl H wrote:bleh to emanage ultimate, and bleaaach to map.
That is like compairing apples and oranges...the EU is a piggyback...PFC is not. You will always get more power out of a stand alone system, but will you pass emissions? With the EU you have great tuneability yet you still remain OBD2 compliant.002-M-P wrote:I agree about emanage ultimate..I have it on the Z right now....Just get a Power FC D-Jetro from Nengun for $690 shipped....much better.
So...where in your list of labor charges do you show machine work to the block? Checking the cylinders for roundness and honing? How do you plan to do that? Also, what if your cylinders are not round...if you put new pistions and rings in and its not round, they'll never seal correctly.Evo_bill wrote: I decided to do it the "right way"
And you think the RB26 stock ecu or any variation of it is ever going to be OBD-II compliant??? You might as well use the stand alone that just happens to be both better and cheaper.jspec603 wrote:
my .02, not trying to argue or steel Evo_Bills thread...just wondering!
You make a good point about the RB ECU being OBD2 compliant...I'm used to dealing with USDM vehicles and NH emission laws. Guess I had it stuck in my head.002-M-P wrote:And you think the RB26 stock ecu or any variation of it is ever going to be OBD-II compliant??? You might as well use the stand alone that just happens to be both better and cheaper.
He going on the fact that the engine is in good enough shape to not need boring. He has the machining costs for decking the block/heads and boring the oil passages.....yet I do agree, anytime you change pistons at a bare minimum you need to hone your cylinders.
Your gonna hone your block out 2mm???? (.078 "HONE??)Isnt the RB26 bore 86mmI think you mean bore it out. I'm not too well versed in machining though.Evo_bill wrote:I've already had my cylinders and pistons measured and I have perfectly good walls along with checked rods. I've already order rings for only 150 bucks and a 88 mm ball hone for 50 bucks. Realisticly Im not going to be running the car at 100%, 600whp. So, I decided to just rebuild stock, everything has check out looking in good reuseable condition, so why spend the extra 1500+ bucks?
maybe in a couple of years when I got deeper pockets and if Im still in to this car, I'll rebuild the motor and ship the car to full race to get the R14 conversion done.
I was one of the lucky ones and got a healthy 3 disk OS Giken with my rblucky7 wrote:i wanna add that a good clutch flywheel combo for a 26 is another $1,000+. OS Giken comes to mind.
a very good start to the list, but i feel like you will run into many unsuspecting pitfalls like i have. simply doing an RB25 is nickel and diming me to death. having the wiring done, power steering lines made, etc, etc, etc. something new pops up every week. and its just another thing to overcome. but again, not dogging on your list. but i know for a fact you will be adding to it. haha.
nope. i've got a receipt in front of me from shae, n1 water pump $147.27Evo_bill wrote:Talk to Shay about N1 water pump I think it was actually only 76 bucks.I haven't fully talking about which size injectors I need so thanks for the input.
gawdzilla wrote:nope. i've got a receipt in front of me from shae, n1 water pump $147.27
