detailed motor specs
cow
Car: beep beep
Does anyone have a website/s that has DETAILED specs on the KA24 and/or the SR20, preferably with diagrams. I am trying to do a bit of extra research on both motors and need to get some stats. I want everything like bore, stroke, rod length, cc volume, materials used, deck height, piston displacement, basically anything you can think of. The FAQs I've found don't go indepth enough. :)
Thanks in advance
lessthanjakejohn
revered D posted this in the Alty KA forum:
KA24DE Internal Specs OEM
Cylinder arrangement: Inline-4 Displacement: 2.389L (145.78cu.in) Bore and Stroke: 89mm x 96 mm(3.50 x 3.78 inches) Valve Arrangement: DOHC Firing Order: 1-3-4-2 Number of Piston Rings: -compression: 2 -oil: 1 Number of Main Bearings: 5 Compression Ratio: 9.2:1
Compression Pressure@ 300RPMs -standard: 178psi -minimum: 149psi difference between cylinders not to exceed: 14psi
Cylinder Head and Valves
Head Distortion Limits: -standard: 0.03mm(0.0012in) -limit: 0.1mm(0.004in)
Valve Head Diameter: -intake: 36.5-36.7mm -exhaust: 31.2-31.4mm
Valve Length: -intake: 101.02-101.62mm -exhaust: 98.52-99.72mm
Valve Stem Diameter: -intake: 6.965-6.980mm -exhust: 6.945-6.960mm
Valve Seat Angle: -intake & exhaust: 45deg 15'
Valve stem end surface grinding limit: less than 0.2mm
Valve Spring Free Height: 45.79mm Valve Spring Pressure: [email protected] -limit: [email protected] Valve Spring Out of Square: less than 2.0mm
Valve Lifter outer diameter: 33.960-33.975mm Lifter guide inner diameter: 34.000-34.021mm
Clearance between lifter and lifter guide: 0.025-0.061mm
Valve Guide outer diameter: -intake & exhaust: 11.023-11.034mm service @ 11.223-11.234mm
Valve Guide inner diameter: -intake & exhaust: 7.000-7.018mm
Stem to guide clearance: -intake(standard): 0.020-0.053mm -intake(service): 0.080 -exhaust(standard): 0.040-0.073mm -exhaust(service): 0.1mm
Valve Deflection Limit: 0.2mm
Cylinder Block
Block Distortion: -standard: less than 0.03mm -limit: 0.1mm
Cylinder Bore(inner diameter): grade1: 89.000-89.010mm grade2: 89.010-89.020mm grade3: 89.020-89.030mm
Out of round: less than 0.015mm taper: less than 0.010mm
difference in inner diameter between cylinders: less than 0.03mm
Nominal Block Height(from crankshaft center to deck): 246.95-247.05mm
Camshaft and Camshaft Bearings
Cam Height: -intake & exhaust: 42.415-42.605mm
Camshaft journal to bearing clearance: 0.045-0.090mm
Camshaft Runout: less than 0.2mm Camshaft End play: 0.070-0.148mm
Pistion, Rings and Pin
Skirt Dia: grade1: 88.970-88.980mm grade2: 88.980-88.990mm grade3: 88.990-89.000mm Oversize(.5): 89.470-89.500mm Oversize(1.0: 89.970-90.000mm
Piston Pin Hole dia: 20.987-20.999mm Piston to cylinder bore clearance: 0.020-0.040mm
Piston Pin Outer Diameter: 20.989-21.001mm Piston Pin to Connecting Rod Bearing: 0.005-0.017mm
Piston Ring Side Clearance: -top: 0.040-0.080mm -2nd: 0.030-0.070mm
Ring Gap: -top: 0.28-0.52mm -2nd: 0.45-.069mm -oil: 0.2-0.69mm
Connecting Rod
Center Distance: 164.95-165.05mm<< Note: Adding the machine clearances is probaly not needed in the FAQ
Bend Limit: 0.15mm Torsion Limit(twist limit): 0.30mm
Little End inner dia: 23.987.24.000mm Big End inner dia: 53.000-53.013mm *without bearing installed Side Clearance: 0.2-0.4mm
Crankshaft
Main Journal Diameter: Grade0: 59.967-59.975mm Grade1: 59.959-59.967mm Grade2: 59.951.59-959mm
Pin Journal Diameter: Grade0: 49.968-49.974mm Grade1: 49.962-49.968mm Grade2: 49.956-49.962mm
Journal Taper: less than 0.002mm Journal Out of Round: less than 0.005mm Runout: 0.04mm Free End Play: less than 0.04mm
Main Bearing Clearance: 0.020-0.047mm Connecting Rod Bearing Clearance: 0.010-0.035mm
cow
Car: beep beep
Wow.. that was fast.. and exactly what I need. Thanks. :D
lessthanjakejohn
no prob
