crazymax »
https://forums.nicoclub.com/crazymax-u19812.html
Sat Dec 18, 2004 3:18 pm
So I finally got my car to run this past week(had to get replacement Ignitor and fix some grounds)..well now it starts on demand but the idle is rough and it wont rev past 2000rpm. I checked ECU and got codes 12 13 and 34
The codes mean:12 Mass Air flow meter circuit / Wiring fault, sensor, ECU 13 Engine temperature sensor circuit / Wiring fault, sensorECU and 34 is the knock Sensor, right?
I replaced the Temp sensor and it did not go away,the MAF I rewired with the KA one using this setup I found in here:
so the Ka Black goes to CA black = groundKA Black/white goes to CA black/white =(12voltska white goes to CA green/black = signal 0-5volts
The Knock Sensor I will wire but I had some Q' about it though,Do i just run a wire from the sensor itself in the block straight into the ECU?Where do I tap the white wire at?before it connects to the harness or till it reaches the connectore by the fuse box?what about the black wire I keep reading about??
The CAS: well I replaced my timign belt and did everythign according to the FSM but something might have gone wrong since it seems like timing is off, when I take off the CAS,is there a correct way it should sit as related to the spline on the exhaust cam??? I also found this"Thanks...I have seen where the exhaust camshaft has the lip broken where the cas plugs in.The engine will turn but the cas won't due to a broken camshaft lip where the cas plugs in."
Is the spline Im talking about(connects to CAS) supposed to be cut accross like in to a point? ill try to get pics..
Modified by DSG!Yashuu at 5:35 PM 12/18/2004
