DjLiquid »
https://forums.nicoclub.com/djliquid-u26615.html
Tue Jun 13, 2006 4:34 am
I would like to throw in my 2 cents since I am a pulsar owner with a ca18det.
an ecu would be a nice start. even though you do have a way to adjust your fuel, you still might not have it adequietly setup. Make sure you have all your sensors plugged in (IE: Maf, IAC, O2, and that other sensor on the intake). Your car won't maintain an idle without some of those. Thirdly, to check your ignition module, inplug each coil pack and put a plug in it. Ground the plug and crank over the engine. Do it to each cylinder and if you have a good spark on each coil, then your ignition module is fine. Fourthly, the timing belt. The points between the cam gears and the exhaust cam and the oil pump, are they 100% correct? The lines could be lined up with the marks on the teeth of the cams but it could still be a crapped belt. Count the number of teeth between each gear when the marks on them are pointed out. There should be 39 cogs between each point. Then from the exhaust cam to the oil pump, there should be 48 cogs.If that isnt your problem, maybe the ca18det that you got could have a plugged injector?
