DET head gasket. Does it exist?
sicj
Car: 1987 Nissan 200sx hatch, 1992 240sx coupe
SO I'm in the process of building up my CA18DET and ordered a Cometic/Wiseco MLS head gasket as well as a full engine gasket kit. Both say they are for the DET. Wrong. Just cause the CA18 blocks are similar outside doesn't mean they are inside. Both the Cometic gasket and the generic head gasket are not the correct ones for the DET block. The DET block has WAAAAY more water jacket galleries. Check the pics....
I've contacted Coetic/Wiseco about this they say it's for the DET as well. I call bull****. So what the hell is everyone that has built up a DET doing for a head gasket?
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
If i remember correctly, it is suposed to have certain jackes blocked off. All the nissan oem ones are like that too. Certain areas of the head werent getting enough coolant cause more flow would go to other areas that didnt need it as much.
Im pretty sure they block the passages to forcemore coolant to more important areas.
Pretty sure i read something to that effect once.
biosehnsucht
Totally normal. That's no mistake, that's exactly how it's meant to be.
In fact, the DE and DET, both FWD and RWD have the same head gaskets.
boost_boy
sicj wrote:SO I'm in the process of building up my CA18DET and ordered a Cometic/Wiseco MLS head gasket as well as a full engine gasket kit. Both say they are for the DET. Wrong. Just cause the CA18 blocks are similar outside doesn't mean they are inside. Both the Cometic gasket and the generic head gasket are not the correct ones for the DET block. The DET block has WAAAAY more water jacket galleries. Check the pics....
You're WRONG! Their supposed to be that way. Good luck at finding a gasket that has holes for all the water jackets.
Dee
meminto
Car: S13 Silvia CA18DECT
Yeah man, thats the way they are, every CA18DET headgasket I have seen including stock ones are like that...
Don't be too quick to call bs just yet..
progman
I believe the idea here is to have the coolant run through the block and then instead of just running to the head where-ever all the flow is forced to the back of the head so it has to run the entire length to the outlet pipe without any shortcuts.
sicj
cool. thanks guys. that's good news.
dash
Car: s13 ca18
DALAZ_68
Car: 90' 240sx CA18det
so to finalize all this...same head gasket for DE and DET,
the one pictured is correct...
quick question....say i need exaust manifold gasket (were the EM meets the block?)
which motor from what car would i ask for if im in SoCal
articzap
Car: 2014 F150 FX4
DE.
fluent
S13 CA18DE/CA18DET is the same (Stock Nissan OEM Item is Same Part Number).
Non S13 CA18DE/CA18E etc is different...
D3stro
Just ask for a exhaust manifold gasket for a Nissan Pulsar 1987-90 with 1.8L engine.
DALAZ_68
aww thanks broddah
