1. Alright my bad for not stating it as a question, seemed like one in my head.
2. I'll look for a short throw because of the shift lever issue(looks terrible, should have a picture up soon)
3. Will inspect/invest in all of those off rockauto/local parts store.
4. Yup, it still of course smokes horrible, but now it won't overheat. the thermostat i put in was the old one from my 86 N/A before I changed to a newer one.
5. Glad I'm not the only one.
6. The cooling system fluid looks terrible, almost like that stop leak stuff in the parts store. THAT BAD. I'll flush it while I do head gaskets and also have a compression test done. The idle issue was caused from the EGR piping not being properly tightened on. Made a huge difference, but now im still tracking some other lines cause it feels like im losing boost.
7. I know you said 10W-30 oil would be fine for my 84 turbo, but would 10-40 be too much? It's starting to get into the high 90s-low 100s so i just wanted to make sure.
Side note: I saw a 84 N/A on craigslist today if anyone is interested. I think its in the northern/central part of Alabama, but I'll double check. They want 800$ cause apparently they need it gone. Just thought I'd post it on here.
