yes, destroking an engine is generally done in the interest of making higher RPM possible.
there *used* to be a fantastic paper on rod length:stroke ratio and the positive/negative effects of moving in either direction on the web, but apparently it's gone missing, so you'll have to do with google's cached version:
http://216.239.33.100/search?q...UTF-8
this page:
http://www.courtesyparts.com/nismo/s13/s13_1.htmlsays KA24 connecting rods are 165mm, center-to-center;so a stroke of 96mm gives the motor a rod:stroke ratio of ~1.719:1
as you can read on the cached copy of the panic tech paper, this is just short of what some consider the "ideal" of 1.75:1, meaning yeah, there's probably a few hundred RPM, and a little engine longevity, to be gained by destroking.
can anyone confirm that the L20 crank can actually be used for this purpose? that'd be a nice motor to have rebello build...
ohyeah, hi, i'm new. i don't actually own a 240/sil yet, but hopefully that'll change tomorrow when i head out to trade my vw gti-16v on a green base-model S14.
