carmo »
https://forums.nicoclub.com/carmo-u91933.html
Sun Sep 07, 2008 8:43 am
Are you destroking the engine for a more favorable rod ratio? What kind of RPM are you expecting? That engine, as is, is very capable of reliable horsepower. The cost on the parts is gonna be ludicrous, and not to mention the machine work. If I where you I would look into low compression stroker kits and forced induction. The stroker kit will provide all your forged internals to beef up the lower end for boost. A set of barely streetable cams will have the thing acting and sounding right. Pile on top of all that, 10 pounds of boost or so and your gonna have to tub the rear end out to fit the appropriate tires. With good tuning, you should have a daily driver pushing 500+ horsepower. For tuning, I would go with AEM EMS and you'll probably have to make the fuel system a return system. Aeromotive has you covered there.
