Megaseth »
https://forums.nicoclub.com/megaseth-u593.html
Mon Jul 04, 2005 5:07 am
the fuel pump is a rather...unintelligent way to wire up the fans for ignition. all you need is it to draw too much current and POP. out goes the fuse and the pump dies. instead, use the AIV plug harness. the brown wire is a 12V on with ignition wire. much safer if you're removed your AIV...which should be done anyway since its poop.
and yes, dont bother with the A/C harness. you just needto have one fan constant, one fan on at a certain temp.
i have a good paint pic of a simple wiring harness if you want it greg, its basic, but it will show the wiring using a relay for one fan. the thermo switch is out of my hands. holla if you want it.
