maxnix wrote:Is your throttle cable adjusted properly (enough slack)?
Well, when I'm out of the car and checking it appears to have enough slack in that it isn't pulling on the throttle. Is that enough?
maxnix wrote:Check the MAF connedtion very carefully.
Think it still could be the MAF? The connections all look good. I forgot to mention that I cleaned a bunch of connectors around the MAF and TPS with electrical cleaner too. Everything seems to be clean and tight to me.
maxnix wrote:Check for vacuum leaks.
I don't see any unplugged lines and don't hear an obvious leak.
