002-M-P »
https://forums.nicoclub.com/002-m-p-u51311.html
Tue Mar 27, 2007 4:28 am
A little bit of vibration doesn't matter that much to me because my original plan was to run solid motor mounts, but everyone tried to turn me off that idea...but I will keep the 80 in consideration.
I plan on welding everything up enough to support the motor and mock it up enough to measure for a driveshaft, then I am going to take it to my friend who does all of the TIG welding on our FSAE car's chassis, just to be extra sure it is all good.
So everyone things that 1/4 inch plate for the two mounting surfaces, then 1/4 wall 2"x2" square tubing for the support arm sounds good? What size bolt should be used for mounting the isolator to the subframe, 1/2-13?
