Desalting Undercarriage after winter.
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
AWGD8
Car: 2008 EX35 AWD JOURNEY
I found a way to desalt the undercarriage of my EX35 using a portable 2 Gallon Deck Sprayer from Menards. Either you buy a "Salt Away " concentrated desalter or the cheaper " CRC Salt Terminator." The Salt away is a bit expensive so I went the cheaper way which is the CRC. I believe most boat shop has the CRC Salt terminator. I only paid $10 for a gallon of concentrated CRC.
The instruction says 4 ounce of desalter per Gallon of water. So before you do all of this, you have to go to manual carwash and use a stronger pressure wash underneath the car. We all know that regular water will not totally remove the road salt. After I desalt the car, I only used 6 Gallons total for the engine bay, and the whole undercarriage and under and behind door hinges area.
After a few days, when everything is , I will then steel brush those areas with surface rust then spray it with rust converter then followed by rust encapsulator. Both are in a spray cans and a lot easier to apply. You can get both from Eastwood.com (Don't buy POR15, it is expensive. )
I live in a condo with 2.5 car garage. So this is the ideal way for me to desalt the car and protect it for the next winter. If you have access to a garden hose, you can just buy some spray kit bottle that can be attached to the hose and that's where you put the desalting liquid and this is much faster process.
The EX35 does not have much rust under the hood even though I never desalt it after winter since 2008. The rust are more at the back where the rear differential is located. (Metals towards the rear area of the differential way up underneath and also the front and back lower arms.
Again, you need to pressure wash the car before desalting if you"ll use a portable sprayer for desalting.
frapjap
'07 Subaru Legacy
Cool man!
Thanks for the tips!
PapaSmurf2k3
Site Admin
I wonder how de-salter works on a chemical level, and if it has any side effects for the metal (or bushings).
Trying to keep things rust free is a b****. I find myself wiping oil on a bunch of the more critical components.
AWGD8
PapaSmurf2k3 wrote:I wonder how de-salter works on a chemical level, and if it has any side effects for the metal (or bushings).
This is the first time I tried doing this. Read the product label and make sure it is ok for metal (aluminum etc) and plastic. The CRC is pretty safe. Yes, rust is rust and living in the midwest is tough for car's undercarriage. $10 per Gallon of concentrated Desalter does not hurt.
1 Gallon = 128 US ounce.
CRC mixture 4 ounces per Gallon of water.
That is 32 Gallons of desalter mixture for $10
I only used 6 gallons of mixture for all undercarriage , engine bay, brake calipers, rims etc). :dblthumb:
I prefer doing this at the end of every winter. During winter, I will use the regular carwash underbody spray.
The problem with salt solution adheres underneath the car is when the weather turns warmer like spring and summer. The heat is the catalyst to start forming rust.
Why not? if it works on boat, jetski etc. I"ll take the risk... $10 is what you pay for a single carwash during winter season.
EXceptional
Car: 2008 Aspen Pearl EX35 Freakin Loaded!
Here's the MSDS sheet for the CRC Salt Terminator...
http://www.crcindustries.com/faxdocs/msds/7932.pdf
Cool thread and tip.
Thanks for sharing!
Now all you need to buy, is a car hoist for the garage.
Ilya
Okay, so, I have a lift and was reading this thread...
1) Go to carwash and wash underbody
2) Go home, get car on lift
3) Spray 1:4 ratio of water/desalter on the entire underbody of the car, etc.
4) Rinse again?
AWGD8
It is up to you if you want to rinse. If you wAnt to leave a protection coating then do not rinse.
The desalter neutralizes the road salt. Since it is Spring season, I would not rinse it. You need to leave some coating for wet road driving. For Summer time, I would rinse it and for Fall I would not.
For Engine bay = rinse
For wheels and brake calipers = rinse
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
