Dent Remover
phil4watching
Car: 06 infiniti g35 coupe
Y'all think this actually works?
http://www.asseenontvguys.com/...ID=49
zozoka1212
Car: 08 Infiniti G35x
never tried it but for some reason I would not trust much. If it is just a ding you can pop out you should be able to do it without that if not that it will be visuall after you do the work.
Somebody probably used it before and can givve you an answer.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
knew someone who got that and it didn't work at all. I guess it's like everything else Billy Mayes sells.
pfarmer
Car: 2008 GXS with technology package
phil4watching wrote:Y'all think this actually works?
This really is nothing new and to an extent they will work but only on certain types of dents and possibly only on certain vehicles. Most I have seen and a couple I have used basically work like a windshield puller. Basically you bridge the dent and then you pull the dent out with another suction cup sometimes attaching via superglue. It just depends on the dent and its willingness to be pulled out.
Most of the time I have had better luck working from the other side rolling them out, sometimes with as little as a spoon. Important in any case is temperature if you want to maintain the paint.
Another method I have seen demonstrated involves induction heating which if done carefully can also preserve the paint.
Perry
av8or
Car: '07 FX35 AWD ... '06 4runner limited ..... A320 F.O. (my other ride)
don't do it... i purchased that thing to take out a small ding and ended up with three... those two supports at the both ends gaved me two new dings... just go to "bumperdoc".. that's where i ended up going... dings need to be pushed from the inside not pulled from outside
phil4watching
Dang. I figured that thing would work. That's upsetting. Thanks for all the responses guys
