dent removal
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
How would you get this big aas dent out? I can get behind it through the trunk and was trying to use a basketball. I took all the air out, stuck it in the pocket behind the panel and aired it up. it's not working all that well. Some of the dent has come out but I think I've gotten it as far as it will go with that method.
I'm trying to get it out as gently as possible. No drilling or welding please......... I don't want to repair holes or tacs from slide hammers.
240sxJoe91
Car: 1991 240sx Ka24de
if you can get a body work hammer behind it use that....
wa-chiss
2005 Toyota Sequoia
I'd be able to get a dolly but not the hammer. I can barely get the deflated ball back there.
Justin35ll
Car: s13 coupe sr20det
I think I have one in the same place. My method to fixing it is covering it with a body it
barefoot mat
Car: twin cam s13 fastback
thier is basicly no other "right way" to repair it besides using a spot welder and slide hammer. grind off spot welds, sling a few layers of bondo on it sand, prime, and paint. unless you just want to screw it up some more. i not trying to be a d!ck. but this is why (good) bodywork cost so much.
wishin_on_an_sr
Car: '89 hatch and '92 coupe
you could try this http://www.youtube.com/watch?v=ILVWPzO_ ... ...latedit may be worth a shot
zer0faith
Car: 2004 Saturn Redline , 2001 Honda Accord v6{saphire}, 1990 S13 RIP :(
that only works on urethane parts.. correct me if I'm wrong but when i working a body shop the easiest way was a slide hammer and or a o/a welder...
