denso iridiums gap
climaxsr20
Car: 1998 Silvia RedTop
well... planning to get the car back soon but just wondering what gap should i have the denso iridiums at? is performance same as NGK iridiums? also im guessing the 92 sentra 2.0 iridiums should be the same right? thanks in advance.
ILikeMy240sx
Car: SR Power
I always use NGK and very happy with it.
BKR7EIX is the one I use. Gap them to .028 inches. I think they come .030 inches from the factory
myees13
Car: 90 s13 coupe
do not gap plugs with precious metal
btw, I prefer ngk copper (bkr 6/7 e)
ILikeMy240sx
Car: SR Power
If you are gapping iridium you just have to be extra careful. It is so easy to snap the electrode.
Copper pugs suck balls. After few weeks they start to misfire like crazy.
myees13
Car: 90 s13 coupe
ILikeMy240sx wrote:Copper pugs suck balls. After few weeks they start to misfire like crazy.
I like to change them frequently, like every oil change. Im weird about that. I have a set of bkr7e-ix. Ill give them a try soon/
ILikeMy240sx wrote:If you are gapping iridium you just have to be extra careful. It is so easy to snap the electrode.
yes, you are correct
from NGK:"Adjusting the gap on fine wire plugs can be done. The reason there aremany cautions not to adjust the gap is because if you were to use a coinstyle gap tool or some other device that would pry or put pressureagainst the center firing electrode, it is easy to snap off the centerelectrode and damage the spark plug. I suggest if you are to attempt toadjust these plugs, use a wire style gap tool or one that has a groundelectrode attachment. This will grab onto the ground electrode allowingyou to change the gap without coming into contact with the center firingelectrode. "
C - ROD
Car: SR20DET pignose hatch
ur not susposed to gap platinum, iridium, or any other plugs that arent copper pretty much
