pancito »
https://forums.nicoclub.com/pancito-u529.html
Mon Sep 09, 2002 6:52 am
ahh more detailed information, more detailed answer.
Still NGK plugs work just fine, i know of people under boost and still with the NGK Brand only one range colder.
correct me if i'm wrong (after all i'm not omnipotent)
Iridium and/or platinum (and i don't know what else) only helps the longivity of the plug, not so much the performance part of it. and unless you have any type of upgraded ignition system, there is no use for "aftermarket plugs"
i think GAP of the sparkplug plays a more active role also good working sparkplug wires, and the rest of the ignition system, if everything is in OEM required specs you should be fine.
