Deleting the a/c for the winter
Graberhieny
Car: 1995 Nissan Maxima
My a/c bearing has now had it and it is too cold to get out there and change the bearing. So this is a question for those of you that have already done this.
What is the new belt size for a 1995 Nissan Maxima when I bypass the a/c?
So far I have been told 2 different sizes: a 37" and 38" which is the correct one before i start on this?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
A/C is actually just as useful in winter as in summer. You don't want to get rid of it. A/C comes on with defroster to remove moisture from the air which improves defrost function.
marlin29311
Car: 2008 Infiniti G35x
MinisterofDOOM wrote:A/C is actually just as useful in winter as in summer. You don't want to get rid of it. A/C comes on with defroster to remove moisture from the air which improves defrost function.
+1. Just blowing air onto your windshield to try and defrost will do nothing - you need to have dehumidified air in order to remove the moisture buildup on the windshield, and the A/c does that - it "conditions" the air - the cooling just happens to be a byproduct of that...
Note that when you put heat on it still comes out warm...
Graberhieny
You guys have really put me down now. This means that I will have to remove the clutch from my compressor and the one from the junkyard that I got and swap them. I really do not want to get out in this colder a$$ weather and work on it. I was hoping that I would have been able to get away with the shorter belt. Well now it is time to get under the car now. I am not going to waste anymore time now. So hopefully my next post will be that I have completed the project properly.
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
cold a$$ weather? how cold is it in georgia right now? about 70* damn southerners...just like my wife (from la)
Graberhieny
It is in the 50's the wind is what makes it bad. I got out there anyways and found out that the a/c clutch is in GREAT condition. I thought my belt was what was burning, but now I do not know. I put the belt back on and let the car run some more and smoke up some more. after like 5 mins of letting the car run all the noises went away and the buring went away too. It is running the way that needs to now. Only thing left now is changing all the motor mounts. How hard are they to change and about how long will it take?
Thanks, Keyur Patel
trent.davis23
Car: 2003 I35, 2001 I30 (totaled)
Graberhieny wrote:It is in the 50's the wind is what makes it bad.
You do know its going to be in the high 60's this weekend right?
Graberhieny
Yeah, I know but I am going to have to work that day. So for now I will drive my mom's 3.2tl. While she is out of town. I will wait for another good day and get out there and work on it. If it comes to the worst case scenario then I will get my brown @$$ out there and work on solving the problem. LOL
allensteiner
front and sides are fairly simple. rear is a pia.
