How did you relocate fuse box, and where did you put it??Ziggy1621 wrote:Here's a list of things I've done and a before/after pic. Not 100% complete, but getting close.
AIV delete
PRVR delete
EGR delete
PCV Reroute
Water Bypass
Fuse box relocation
Fuel filter relocation
Hicas delete
(Cruise control is out in the pic but going back in next week when my speed sensor gets in)
Mild wire tuck (still have to tuck the injector and coil pack plugs
For the wire tuck did you have a new harness? Cause mines hard as a rock and probably would fall apart if i tried to tuck it or bend it lol, but kinda just curious if you had to extend any injector/plug wires or not?Ziggy1621 wrote:Thanks. Fuse box is under the nose panel on the right. Fuel filter is below the Brake Master Cylinder
