Delema!!!! What shoud I get now???
Nissan-S14
Car: 95 Nissan 240SX SE
Alright I have a delema I have $250 limit. These are my current mods.
K&N IntakeBlitz Nur-R Cat backEnjuku Racing aluminum driveshaftJ30VLSDTein Tie rods & rod endsTein Tension Rods300ZXTT front brake conversion
So now I was thinking eitherA) Rs*R Springs $220B) Tanabe Springs (wont blow my stock struts) $120C) Suspension Techniques Sway Bars (save for coilovers but might be a long time) $240D) Something else???
Comments and suggestion are welcomed.
574-240sx
Car: Nissans, Toyotas, Subaru
With spring you will be happy til so long. If you don't buy springs and struts at the same time its almost not even worth it. I would vote save but its really up to you.
Silvia007
Car: 93 Nissan 240SX SE Fastback
If you would rather not save and want to buy something, I'd get the sway bars.
Nissan-S14
Will the sway bars decrease the chasis roll? Or will I still need springs for that?
MAXIMUS Nismo
Car: 95 240sx SE
go with the sway bars if you have to buy something now. here is a post I made that will give you more information about them.
http://www.nicoclub.com/zerothread?id=102471
Nissan-S14
Ok so sway bars it is, now here is another problem. Should I get Suspension Techniques or Tanabe Sway bars, I can get Tanabe sway bars for $273 for both and ST I can get for $275 for both. Now I believe the ST come with end links as Tanabe do not. Is that right? Anyone here have either one?
MAXIMUS Nismo
Car: 95 240sx SE
ST come with new endlinks becaue your old ones may be worn out and can't handle the extra stress that newer, stronger bars will put on it.
