proxim2020 »
https://forums.nicoclub.com/proxim2020-u47252.html
Wed Nov 22, 2006 12:55 pm
Bring it in. Changing your diet will requires too much effort. When I used to have a car, the A/C drain tube got clogged with a leaf or 2. I thought it was just stinky carpet but I discovered the real problem when running the A/C on a hot summer day. I turn a corner and all this water spilled onto the floor from the dash. The water would drain slowly and cause a funky mold smell. That day, there was so much moisture that the water had no else where to go. You can check your carpet for wet spots also. There was another user who had a problem with the A/C draining under the carpet. He had to have all the carpet replaced. It could be the in cabin filter, if there's one and it's located before the defrost tubes.
