I thought it was recommended to Defrost with the air selector on FRESH, not RECIRC.Ever Victorious wrote:2) The lever should be to the left only when you are trying to bring fresh air into the car. Whenever the A/C is on (for either cooling or defrosting), the lever should be to the RIGHT (recirculate). Having the lever in the wrong position will not hurt the car, it just makes the climate controls less efficient when you use it in the wrong position.
This is correct. Although in more extreme conditions, you have to decided if warmer air is more improtant that lower humidity. In sub freezing weather when the engine is cold, it's a tough call. I often start at recirculate and rely on the load from the rear defroster and blower fan to load the engine to help it warm up faster while I scrape the ice or snow off the car.Rockhound wrote:
On my 2003 Altima, I have this behavior. Is there no software/firmware fix for this "feature"? It tends to defeat the efficiency of my 4-cylinders...BBISHOPPCM wrote:This, believe it or not, is an improvement from the original design! On previous Missan products, once the defrost is selected, the A/C could only be turned off if the blower is turned off (but would turn back on if the blower is turned on regardless of vent selection). To reset this, you had to literally shut down the vehicle.
