Cyberkreig »
https://forums.nicoclub.com/cyberkreig-u962.html
Sat Jan 18, 2003 7:35 pm
Got my 240 back today. After several months of delays. Anyway, Shop informs me there is a small boost leak. The tried and true brake cleaner test reveals the leak is in the area of the IC. (Stock SMIC).
Get it home, and pull the SMIC, the leak revealed itself as being on the seal between the 'hot' pipe and the IC itself. It was extreamly easy to spot due to a copious amount of thick used black oil (or what appeared to be). However, the engine oil is extreamly clean, maybe 100miles on it.
Where might this 'oil' be comming from? If it was a bad turbo journal seal wouldnt it be the same color oil as that from the motor?
Thanks for the help.
Didnt mention, the exhaust doesnt seem to be smoking, but then, it is very cold here and smoke would be hard to spot.
