Defi HUD tach signal?
Reignman
Car: 1995 240SX
I am installing the Defi VSD Concept on my S14 with SII Rb25 and I cant for the life of me find a tach signal to run it off of. I have tried running off pin 26 on the M63 plug, pin 7 on the ecu plug, the loop on the ignition harness and the white wire connecting to the coil pack and have gotten nothing. Right now the tach in the gauge cluster doesnt read anything but the Power FC is getting a tach reading. I cant figure out why the cluster gauge wouldnt be working if the ecu is getting the tach signal. Does anybody have any ideas on how I can get the Defi unit a tach signal?
kjlindgr
Use the pin on the ECU. Your body harness must not be hooked up correctly if your cluster isn't working either.
EDIT: Pin 7 is an output signal for the tachometer. The ECU probably calculates RPM via the CAS and so this is why your PFC shows RPM but nothing else does.
Reignman
Car: 1995 240SX
kjlindgr wrote:Use the pin on the ECU. Your body harness must not be hooked up correctly if your cluster isn't working either.
One thing I did notice was that the CAS is supposed to have a 120deg signal (pin 51) and a 1deg signal (pin 52) but I dont see a wire at pin 51. I thought that the series II motors might be differant and this wasnt a problem since the PFC was still receiving a rpm signal. My harness might be incomplete so I might just need to run a wire from the CAS to pin 51.
Carl H
the car wont run very well if the cas signal is wrong...the cas has 2 signals 120 and 1 or sometimes 0 and 180, one serves as the actual cas signal and the other is a check signal.it sounds like the harness wasnt done right if the cluster isnt working...any loose wires hanging round?ive also found that if the harness isnt grounded properly then the cluster wont work correctly and the car runs a bit funny.
Reignman
Car: 1995 240SX
Carl H wrote:the car wont run very well if the cas signal is wrong...the cas has 2 signals 120 and 1 or sometimes 0 and 180, one serves as the actual cas signal and the other is a check signal.it sounds like the harness wasnt done right if the cluster isnt working...any loose wires hanging round?ive also found that if the harness isnt grounded properly then the cluster wont work correctly and the car runs a bit funny.
The ecu plug is missing the wire for the 120 signal but I do see that the wire is there on the CAS plug. The funny thing is my car is running very well and starts up right away. I wonder if this wire is in a differant pin on the series II harness. I did the harness myself and I double checked the tach wires and both are connected correctly so Im guessing it must be the CAS wire thats the problem. I will also check my grounds to make sure they are all grounded.
jacksonbrown
Car: 1989 240sx/RB25DET , 1989 240sx/355 Chevy
Hey I have the same problem with a S2 rb25. Mine runs well also just occasionally if I turn the key on but don't start it the dash lights will stay on indefinitely. Did you figure a way to get a signal or possible wiring prob?
