Defective Dotmatrix LCD
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
mgreenb561
Car: 2011 ex35
Just bought 2011 EX35. Black background of information center has snowflake like pixelations. The white foreground works fine.
My google searches tell me i can replace wgole panel ($1080) 6 yr old car-not happening. Or try to find one in bone yard or Ebay. If I try that, can anyone tell me which models and years are compatible with my 2011 EX35??
Does anyone have any other solutions? If I manage to find an electronics guy that claims to be able to repair lcd displays, will the car be operable if i run it witj=hout that panel?
Any help appreciated
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
The model number depends on the manufacture date. The first one is:
Infiniti/Nissan DISPLAY UNIT-AV Part No.: 280911BU0A Production Date: ?
The second one is:
Part No.: 28091-1BY1B Production Date: 10/2009-07/2010 Replaced by: 28091-1BY2E
The third one is:
Part No.: 28091-1BY1E Production Date: 07/2010-12/2010 Replaced by: 28091-1BY2E
The forth one is:
Part No.: 28091-1BY3A Production Date: 12/2010-07/2012
Display unit was used in these vehicles:
EX35 2008-2012
EX37 2013
G25 2011-2012
G35 2007-2008
G37 2008-2013
Q40 2015
Q60 2014-2015
QX50 2014-2016
Armada 2007-2015
Maxima 2009-2014
Murano 2008-2014
Pathfinder 2007-2012
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
There are quite a few of these (used) on eBay, prices range from around $100-$250.
Just do an Ebay search using the part numbers listed by "Rogue One", find out the build date of your vehicle and make sure you get the part # correct.
mgreenb561
Car: 2011 ex35
Thx. Except that is for Navigation.
My problem is the 'Dot Matrix Liquid Crystal Display' that provides info such as odometer , mpg, mph, warnings etc. located in the middle of instrument cluster
Teknical
Car: 2014 QX50 AWD
It's going to be work similar to this https://www.youtube.com/watch?v=fIbIwRxcD1I
You might try working on the ribbon cable connectors or reseating them. Consider ESD protection for this kind of work. I have fixed LCD ribbon cables on occasion, but just as often I've broken them entirely. I think G37 or G35 screens should work in our car too. In the video he shows exactly how to fix the ribbon cable. There are some other techniques.
Rogue One
2022 Honda Pilot SE
mgreenb561 wrote:Thx. Except that is for Navigation.
:rolleyes:
mgreenb561
Car: 2011 ex35
Thx. I can try playing with the ribbon cable, but I really don't think that is it. The information display is perfect. It is the black background where the problem is.
I kind of thought this was more common than it actually is
Teknical
Car: 2014 QX50 AWD
If that's the case then it's either the adhesion of the backing or polorizing layer. You're not wearing polarizing glasses by chance are you? It would really help if you could include a photo.
mgreenb561
Car: 2011 ex35
Id tend to agree w you on cause teknical but don't know the fix. Played gingerly w ribbon cable....did nothing
Here's a pic
Teknical
Car: 2014 QX50 AWD
That is really bizarre. It almost looks like a worm has gotten into it and eaten the LC layer, but that doesn't seem possible. I'll do some research, but I think that whole screen needs to be replaced.
Teknical
Car: 2014 QX50 AWD
Update: the screen is cracked and leaking LC. It may get worse in high temps.
sev
Car: 2010 Infiniti EX35
I have a spare instrument cluser for a ex35. I bought it to transplant some dead LEDs.
I have the middle LCD panel, but it is red and from a 2009 or 2010. (cant remember)
mgreenb561
Car: 2011 ex35
Thanks guys.
I feel somewhat good that it's not a common prob.
Sev, if you've still got that and it'll fit, I'd like to try to get it. In fact, if I'll be pulling instrument cluster, I think I'll probably be able to change out some bulbs to red. I'd like to try to get in touch w/ you....I'll send you a private msg
mgreenb561
Car: 2011 ex35
Sev, it appears as a new user I do not yet have private message sending privileges. Though I haven't seen a rule as such, I would imagine i shouldn't be posting an email of phone #. If you could PM to me, I'd appreciate it. I'd like to see if i can get that panel. Thanks
mgreenb561
Car: 2011 ex35
Teknical
Car: 2014 QX50 AWD
If you don't hear back from that user, and to eliminate the risk of soldering problems when you transplant that part, you could just get a new cluster from here: http://www.ebay.com/sch/m.html?_odkw=&_ ... r&_sacat=0 ebay user lkqonline has lots of parts and I've bought from them before with excellent results.
mgreenb561
Car: 2011 ex35
Thanks Teknical Sev got back to me....he was great, but in the end I won't be using his panel (because I need to stick with a white LCD). I'll be checking out lgqoonline, but I have some questions, just so I only have to do this once. I am on the hunt for a compatible part. I can do a little soldering but i was under the belief that the LCD was connected by a ribbon cable. If I change out entire instrument cluster, i believe I have to get it programmed at dealer? Am i correct on one or both points?
Can Also, not a major objective to change bulbs, but i am uncertain about the leds on a 2011....are they soldered on to circuitboard or are they t5 bulbs?
I am seeing a bunch more instrument clusters for G25 and G37. I know the whole cluster won't just pop in, but I'd be guessing I can take the Liquid Crystal Display out and it would be the same LCD. Am i correct?
I see some clusters for sale stating they are out of car w/ nav. I don't have NAV; does it matter?
Any input greatly appreciated.
sev
Mgreen,
The clusters definitely do not use bulbs. They use SMT LED's. The reason I have my spare cluster is a bunch of LEDs died on my cluster and it annoyed me, so I went out bought a donor cluster and did some soldering work to transplant.
I am about 99% sure the LCD is attached by ribbon cable, I dont remember having to do soldering to remove it. As far as replacing the entire cluster, I'm sure it's possible, but would require programming to get the mileage correct. My experience with getting infiniti dealers to program anything is not very good. I tried to get them to update my bluetooth module, and it took a few trips to get them to understand what I was looking for.
I dont have direct experience with Nissan/Infiniti, but on BMW's, if you plug in a new cluster in the car, the mileage is stored on both the cluster and another module in the car. The car compares the two stored mileages (cluster and module) and goes with whichever is higher. So say your car has 50k mi, and your donor cluster shows 70k mi, the car will display 70k miles. I'm sure infiniti has a similar system in place.
I would think it would be easier to buy a donor cluster and transplant the LCD. While the G25/G37 clusters look the same, if I were you, to be on the safe side. I'd get an actual ex35 cluster to be sure the LCD is compatible.
Here's a cluster that should work for you.
http://www.ebay.com/itm/2011-2012-Infin ... ft&vxp=mtr
mgreenb561
Car: 2011 ex35
AARGH Haven't caught a break yet. I was advised that this listing is for a car w/ Nav and my car is without Nav and it matters. I don't see why it would matter but that is what i was told. Does anyone know if or why it would matter?
Teknical
Car: 2014 QX50 AWD
No, I don't think nav would matter.
I want to hear the Bluetooth module upgrade story please!
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
