NutriaforBreakfast »
https://forums.nicoclub.com/nutriaforbreakfast-u77129.html
Fri May 09, 2008 2:30 pm
Just replaced the valve cover gaskets on my 1995 Nissan.You have to remove the coils but not the plugs.The tricky part is the plenum or upper intake manifold. Be sureyou label all your hoses and electrical connections with tape markersso you can snap it back together. I went ahead and replaced allthe hoses which had difficult access since they were old. The hardpart for me was the bracket bolts on the plenum and the EGR tubebolts close to the firewall.
I also recommend cleaning the IACV which is the large item next tothe throttle body. It tooks five minutes and corrected my idle problem.
I also replaced the seals for the spark plugs and the PcV grommetin the valve cover (easy). Be sure you put them in the right way. On the valve cover, you only want to put theblack sealant in the valve cover groove and install the valve covergasket in the groove. You will need extra sealant along the edgesclosest to the beginning of where the camshaft start. You need toget a Haynes book which shows you how.
Be sure to use a torque wrench on the valve cover-INCH pounds NOTfoot pounds
