Trigger »
https://forums.nicoclub.com/trigger-u5777.html
Sun Jul 16, 2006 6:35 pm
ok Dee (or anyone) when i start the car i have to feather the throttle a little to keep it cranked then when it warms up it idles at 1500-2000 rpm's I have replaced the temp(and rewired) sensor, tried a friends TPS, MAF, new o2 sensor, hooked knock sensor up, I cleaned the AIV, no vacuum leaks. at this point I am stumped. The only thing i can think is a bad AIV so i am going to go to the junk yard and pulling one off a Q45 to see if it makes a difference. I also have a safc2 that i am going to install and see if i can fix it with that. If you dont remember my car ran great and then i upgraded the turbo and cams and put the fmic on and it has been like this ever since. any help would be great....
Tim
