NismoBgt wrote:...What are we talking on the build up? custom cams? pistons, head work? thats what I need an idea on.. how to get there... The dollars are not such the issue. I have a sponsor..
As for the build here would be where I'd start...-A Good N/A cam grind. Call Colt Cams in Canada. They know their stuff-Try and source Valve springs, retainers, valve guides, ect. You can get stuff from Japan, but it'll take forever, IF it's even still in production. I'd try and get something custom locally in the US. -Have the head, and manifolds PORT MATCHED and polished. You might consider having the whole intake manifold/head/exhaust manifold extrude honed. That would give you the PERFECT intake and exhaust paths. If you do that, have the ports that have the injectors in them roughened back up after the honing so that you get good fuel distribution and dont get any pooling in the head. -AFAIK there aren't any commercially available CA18DE headers. You MIGHT find one from Japan, but once again, time and money. I'd reccommend a custom 4-2-1 header. -The stock head bolts and HG should be up to the task, but ARP headstuds and some sort of metal HG wouldn't hurt if $$$ allows.-Custom lightweight forged pistons. Probabally in the 12-14:1 range. Anything over 14:1 isn't really worth it IMHO, too much chance for detonation and not that much gain in power. -Custom lightweight (titanium if $$$ allows) forged rods. I like H-beams. Probabally Eagle or Pauter.-ARP rod studs and main studs. This will take some work with ARP to get figured out as they don't have any specific kit for the CA.-Lightweight flywheel. They can be had from Japan, may or maynot be hard to find. There is rumor that the SR20DET Fidanza flywheel will work, but you've got to use a Hitachi, gear reduction style starter from a CA18E(T) powered S12. -Some sort of good clutch. With the high revving motor that we're trying to build I'd HIGHLY reccommend the Centerforce Dual Friction Clutch with the weighted fingers. The faster you spin the motor, the harder it grabs. I THINK they've got one that would bolt up to the SR20 flywheel, or if you use the CA18DE(T) flywheel, you can use a clutch for a KA24E out of an S13. You'll have to remove one of the alignment pins on the flywheel, as it's off a bit. -Have the ENITRE (pistons, wrist pins, rings, rods, crank, flywheel, clutch) reciprocating mass balanced. -Try to find a high volume oil pump. I think TOGA makes one. Not sure what the availability is like. I'm not sure how the stock oil pump will like 8K+ RPMS. It may or maynot be fine. Your other option is an external sump system. This will require a custom oil pan, but will be good to what ever RPM you turn the motor at.
That should pretty much get you there. I'd TRY and do SOMETHING that will allow you to keep the stock butteryfly's. Maybe a mechanical rpm switch that controls the vaccuum going to the actuator? It'll need switched around 4K.
I'm also not sure how you're going to pull off the ignition timing either as the CA18DE(T) was never set up for any sort of distributor. It was strickly run electronically. I would assume since you're fabbing up something for the mechanical injection, you'll be able to feed an ignition signal to a coil and distributor.
If that doesn't get you there, nothing will...
