azncorruptedo17 »
https://forums.nicoclub.com/azncorruptedo17-u17403.html
Sat Aug 28, 2004 2:17 pm
with a bad alternator your car won't even start, and will eat up the life of your battery. I've seen 4 of our cars have bad alternators all with the same description you have given, if its a clicking noise when turning the key it is possible you have a bad/clogged alternator, if its clogged goody since all you'll really need is to pull it out and clean out the gunk and stuff with brake fluid. Or you can always buy a refurbished one. But best to check your alternator first since that is an easy check just take out the 3 bolts its being held on and check out it.
