BuddhistWitch wrote:Oh, sorry I must not have mentioned. Aside from being cheap and all, I want most of these parts to be useful for future upgrades and up to higher boost. I mean come on, who wants to be runnin on 7-10 boost forever? I know that driving turbos makes you boost hungry, that's why I wanted to boost in the first place, and I know that I'm going to be hungry for more after this.
Well, You really can't have both dude. You can't have a tiny used turbo and then expect it to be able to push higher hp. You need to decide what you want right now. I won't ever tell someone to run without a IC. They are to easy to find for a cheap price.
Here's as cheap and decent as you can go.
Find a set of injectors on EBAY, 370 or any sidefeeds bigger then your current injectors (280)Use the Hacked MAF to control them.Get a T3 or better from Ebay, watch what size motor the T3 came off of, somthing atleast close to a 2.4 liter.Build your own oil supply and return setup. Look around here for the proper sizes, nm here's a link http://www.nissaninfiniticlub....ber=2Find a cheap IC from Ebay Use whatever you can to run IC piping, PVC, mild steel, crush or mandrel bent. Basically whatever you can find for cheap.You can't run very much boost without having some kind of Ignition retard, so don't go over 8 psi unless you manually retard your timing a couple of degree's. But I would still not run very much boost, unless you get a MSD BTM.
Spend a little more on the above parts now and save alot on the back end.
WD
