deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sun Apr 02, 2006 4:34 pm
nissanfanatic, you have no idea what you are talking about. I dont really want to argue with you either, it is pointless. We are not talking ecu "theory", we are talking about the facts, very simple stuff. If you do not understand the operation of load and rpm lookup on an ignition or fueling table, you need to do some reading before you go defending a piggyback controller.
When decreasing maf voltage to trick the ecu into fueling differently, your chopping massive amounts of resolution off of your main efi controller. You do not see timing change, dont you mean "it doesnt change very much". Well if you would look at any given timing table for any given efi controller, you will see how timing advance relates to load. By decreasing load you are shifting timing that would normally be used by medium load, to full load as defined by the signal that is modified by the piggyback. This may only be a couple degrees, maybe only 1 degree, but the drop is resolution is still very drastic and extremely inferior to working with full or even increased/shifted resolution. You are basically neutering the capability of the original (or tuned) ecu.
Now, like you, a lot of people do not care about things like resolution and fuel control. As long as afr is decent at full boost and your engine does not explode, you are content. This mentality is your limiting factor, there is more to efi than idle and wot, the more resolution and fine tuning you can provide the more power you will make, reliably, simple as that.
Whats with all these damn knuckle draggers in the ka-t forum, seriously? Go drink some beer and work on your ka-t, lol.
