The engine is from an R32 Skyline. He says it runs ok but needs to be tuned.
My biggest question for everyone here, is would it be worth paying $8000.00 for this car or am I better off starting from scratch? Thanks!
Provided the engine is in good condition, you won't need a rebuild at all to reach 450 with a RB26. They produce a lot of power easily, but they're on the expensive side. Carl told me a RB26 would be overkill for my goal of 400whp.Steveb18c wrote:I am still waiting on the pictures to be posted to my email. It also has an s15 conversion but the paint on the car doesnt look too good. I have never worked on the Rb26dett but I can imagine it is no cheap build. I was planning on rebuilding the engine to handle 450 whp.
From what I read and see people talk about, the RB26 is the most expensive RB to deal with because parts are harder to get.Steveb18c wrote:How much is on the expensive side? I am just glad its already installed and everything. Ill try to get more details and post them when I receive the information.
Jabberwocky wrote:If it were me I would leave it alone. That's a fairly complicated and expensive swap, same thing with the s15 conversion, and there is the potential for a lot of issues to arise. The biggest PITA is trying to reverse engineer someone else's work to troubleshoot and fix a problem.
The only way I would remotely consider it is if it were done by a reputable shop and the owner could produce all the documentation for the build. Another thing to seriously consider is what badbob brought up...is it going to pass inspection and/or emissions so you can even tag it?
If you have 8000 to play with, are lusting for an s chassis, and have a reliable mode of transportation now I would consider all of my options (RB, SR, KA, yadda yadda) and then make the decision after researching and knowing exactly what you want.
I couldn't give you a very accurate estimate, but I can say that while researching and deciding what I wanted to do I pretty much ruled out the RB26 because of cost/part availability. I teetered between RB25 and KA-T before I talked to Ivan from KA-T.org (back when he was still at PhatKAT, lol) and he pretty much sold me on the KA.Steveb18c wrote:How much do you think it would cost to start from scratch? Just from what you have read or experienced?
2JZ doesn't sound as cool as a 1JZ or RB. :PLobo240sx wrote:2JZ ftw. RB is a temperamental and expensive engine to play with.
badbob2121 wrote:Depending on the quality of the swap... and the overall condition of the car.. possibly
A good buddy of mine has a rb26 coupe. They are not cheap engines to play with...
Do you plan on registering this in CA? If so, you might want to do some research and ensure you are willing to deal with the hassle of it being "legal" in the horrible, horrible state you live in....![]()
It would help if you posted pictures...
To me 8k sounds a bit steep. The thing is no matter which RB you have they are all expensive. This is especially true with the older models like the r32. Just in my experience they will nickle and dime you to death. Before you could even begin the upgrades there are so many things that need to be checked/replaced and its all bookoo bucks $$. Just little things like fixing the crank collar issue the early model rb engines had (which is highly necessary) involves buying the extended collar which is about $120 then taking the engine apart to take out the crank, have the extended collar put on the crank and assemble. They are real sweet engines but you gotta know what your in for, i knicknamed my car "the money pit" lol.Steveb18c wrote:How much is on the expensive side? I am just glad its already installed and everything. Ill try to get more details and post them when I receive the information.
