Maybe so, maybe not. Might want to read http://www.stoptech.com/whitep...e.htmsijoko wrote:Regarding the Skyline brake upgrade: All you need are the front calipers, front rotors w/ new pads and the install kit (shims, slides and spring).
so could we bolt on a q45 master to a s13 brake booster or do we need a brake booster 2...or will the whole thing not bolt on.... becouse more clamping force is always good... i have the 180sx brakes that i got off my clip and they where much larger then the stock..thankselwesso wrote:Upon further research I found that Z32 front brakes may actually be LESS powerful in clamping force than the Qs...
The Q master cylinder is SIGNIFICANTLY more powerful than the Z32.....
Z32 master cylinder- 853 PSI, front- 526-583, rear
Q45 master cylinder- 1067PSI, front- 796PSI, rear
You are jumping to conclusions way too fast.elwesso wrote:Upon further research I found that Z32 front brakes may actually be LESS powerful in clamping force than the Qs...
I am basing ALL of my informaiton that comes from the FSMs... Using my 1994 Q FSM and a 1996 Z32 FSM.....
The cylinder bore diamater in the Z32 fronts is 1.5925in x 2 (odd because theyre 4 pistons, but maybe thats only one side)
The cylinder bore diameter in the Q Fronts is 1.685 x 2
So using those figures, its easy to see the clamping force of the Q fronts will actually be STRONGER... Very interesting stuff here...
Seems that a Z32 guy would want to do a master cylinder upgrade before doing anything else..... Z32 has great brakes and just needs a new MC..
Even if I get to the point where I need less rear action, i can install an inline pressure control valve... The Q stock brakes in the front, besides the width being inadequate for life are more than necessary for daily driving... I can live with a little vibration and when it gets real bad i can upgrade or get new rotors.....
I think you mean the solid rotor area is 1mm thicker on each side of the vented area. It's really all about mass when it comes to the rotor staying true under thermal loading. Why Q45 tech has said the gains from the Z32 rotor are not significant enough. They were designed for a 700+ pound lighter car, so something heavier is indicated for the G50.Nismo_Freak wrote:Not only that but the Z brakes are 2mm wider in diameter to combat brake fade.
Interesting to note that the all the non brembos besides the R32 GT-R <non vspec> use the the same (Z32) calipers in the front..... So you can always upgrade rotors at that time.moderator forum thread wrote:m looking to upgrade my Q45 brakes..... Was thinking about using Z32 parts, as I already have Z32 calipers for the rear and Z32 rear rotors...
Does SPL sell skyline brakes.. I saw they have the skyline rotors.. Are there really any appreciable differences between the skyline and Z32 calipers, as far as clamping force... Id save some money by going with Z32 brakes...
Any suggestions?
Post Title:Posted by: Nismo_Freak at 12:42 AM 3/4/2005
You'll need 17's to fit the good GTR brakes and even so the brakes themselves are rare and costly.
You'd be better off doing this:
- Z32 4-Piston Calipers Front- Hawk HPS Pads- New Rotors from 93+ Z32- Home Depot Air Ducts to Brakes
With good ducting you should have little problem with fade in normal street usage.
Oh and gut that pig of a car
Post Title: Re: (Nismo_Freak)Posted by: elwesso at 2:38 PM 3/4/2005
I have 17s anyway, so thats no biggie......
Do you like the "greenstuffs" pads?
Whats the difference between the 93+ and earlier?
Is it easy enough to use R32 GT-R rotors and Z32 calipers?
Post Title: Re: (elwesso)Posted by: Nismo_Freak at 2:43 PM 3/4/2005
Quote, originally posted by elwesso »I have 17s anyway, so thats no biggie......
Greenstuffs won't work well on the Q.
93+ ensures you will get the 30mm rotors
GT-R rotors are too expensive to get for replacements, I'd stick with Z32 30mm rotors.
Air ducts are the key to making the 30mm rotor work.
Post Title: Re: (Nismo_Freak)Posted by: elwesso at 4:23 PM 3/4/2005
OK well Ill start shopping for some Z32 rotors and calipers.....
Post Title:Posted by: AZhitman at 12:14 PM 3/5/2005Wes - I'm a distributor for RaceShopper.
SP slotted (or drilled) Rotors and Hawk pads...
Check out their site and lemme know what you need.
Post Title: Re: (AZhitman)Posted by: elwesso at 4:09 PM 3/12/2005
Greg can you get me some pads???
Hawk whatever i need..... can you do a combo of Q45 fronts and Z32 rears???
I think im going to just try the rear brakes with the stock fronts?
Does anyone know if rear Z32 brakes will clear the stock 15s?
Post Title:Posted by: AZhitman at 5:35 PM 3/12/2005
They won't clear 15's.
I can get wholesale pricing on Hawk and SP rotors, SS lines and ATE SuperBlue.
Z brakes rear only may be problematic proportionally, esp given your driving conditions in IN.
Post Title: Re: (AZhitman)Posted by: Nismo_Freak at 5:45 PM 3/12/2005
Quote, originally posted by AZhitman »They won't clear 15's.
He could remedy that with a simple in-line pressure valve.
Post Title: Re: (AZhitman)Posted by: elwesso at 5:48 PM 3/12/2005
I dont konw if you saw my post in infiniti general in the brake upgrade thread but i think this should be good... I didnt post what im about post here though.
The Q front brakes with the Q master cylinder actually have more clamping force than the Z32 with Z32 master cylinder..... The stock Q front brakes have more clamping force any way you slice it (at least as far as Ive investigated) than the Z32 fronts (which is SURPRISING).. I think if we had real good tires in the rear (which is no 1 in braking anyway) we should be OK... Plus, worst case scenario if I dont like it I can just upgrade the fronts... Ive done enough math today to figure out that its at least worth a shot... We're increasing clamping force overall by 14% over stock, and doubling it in the rear..... The Z32 rear calipers are really strong... Basically 2x the clamping power of the rear Q... Read my post and all shoudl be enlightened... Very long.
Long story short, the rears only are at least worth the old college try.....
I dont need rotors, and I dont really want to do SS lines (unless theyre really worth it).. I was just planning on using valvoline fluid since I plan on chaning OFTEN because im getting one of those vacuum pump things...
Post Title:Posted by: J-Spec Tuner at 11:14 PM 3/12/2005
Increased rotor mass is way more important that clamping force if your goal is eliminating brake fade. If you want a good brake bias and better fade protection, do the Z32 calipers and rotors all around with a Z32 master cylinder (if it fits the q45 brake booster).
Post Title: Re: (J-Spec Tuner)Posted by: elwesso at 8:51 AM 3/13/2005Quote, originally posted by J-Spec Tuner »Increased rotor mass is way more important that clamping force if your goal is eliminating brake fade. If you want a good brake bias and better fade protection, do the Z32 calipers and rotors all around with a Z32 master cylinder (if it fits the q45 brake booster).
I am going to maintain using the Q45 master cylinder as it produces quite a bit more effective pressure.....
REally the brake fade from the 28mm Q rotors isnt that bad (fine for street use) so the 30mm Z rotors should be even better..
Basically the way it stands is Ill get 2x the braking power with Z32 brakes... Plus its almost cheaper than rehabbing the stock Q brakes!!!
Post Title: Re: (elwesso)Posted by: repo man at 9:56 AM 3/13/2005
Damn Wes, do you really drive that hard on the street that fade is an issue??? I need to see this...
Post Title: Re: (Nismo_Freak)Posted by: EZcheese15 at 11:21 AM 3/13/2005
Quote, originally posted by Nismo_Freak »
I don't know that the R32 and R33 rotors are the same, but I remember this similar disussion on the GTR mailing list a couple years ago. If I recall, the Z33, V35, and R33 rotors and calipers are all the same. Somebody crossreferrenced all the part numbers.
Post Title: Re: (repo man)Posted by: elwesso at 11:34 AM 3/13/2005
Quote, originally posted by repo man »Damn Wes, do you really drive that hard on the street that fade is an issue??? I need to see this...
One reason why i said the previous violations of the Q werent that big of a deal... i *really* like flogging the brakes..... Ive encountered the fade a little but not that often... When you dont get above 50mph in Anderson hard to be hard on the brakes all the time.....
Quote, originally posted by EZcheese15 »I don't know that the R32 and R33 rotors are the same, but I remember this similar disussion on the GTR mailing list a couple years ago. If I recall, the Z33, V35, and R33 rotors and calipers are all the same. Somebody crossreferrenced all the part numbers.
The thing about the R32 GT-R (NON vspec) is that they are the oddball fo nissan brakes.... They are 32mm wide as opposed to 30mm... The R32 Vspec, R33 GTST, and R34 GTT are all the same, and R33/34 GT-R are the same... The base skylines all use the Z32 brakes or something similar.....
Post Title: Re: (elwesso)Posted by: Nismo_Freak at 12:26 PM 3/13/2005
V Spec GTR's all have Brembo calipers.
The R33 GTS25T / R34 GTS25T (GTT as you called it) all have the same Nissan 4-pot calipers.
Post Title: Re: (EZcheese15)Posted by: Nismo_Freak at 12:30 PM 3/13/2005
Z33 and GTR calipers are different.
There was a giant Brembo comparison in a Japanese mag where they compared all the calipers from the EVO, STi, GTR, Z33, etc. in relation to interchangeability (new word haha).
Post Title: Re: (Nismo_Freak)Posted by: elwesso at 2:29 PM 3/13/2005
Quote, originally posted by Nismo_Freak »V Spec GTR's all have Brembo calipers.
Thats what I was saying... The only non brembo GT-R is the R32
I have this PDF file that has all the nissan brake dimensions, and they referr to it as the GTT and ive seen it referred to that on other sites as well.....
BTW Alan, you spell YAO MING as spelled wrong in your sig... YAO instead of YAU
Post Title: Re: (elwesso)Posted by: EZcheese15 at 2:34 PM 3/13/2005
Yeah, also if you have ever seen the back of one, it says GTt on the trunk deck.
http://www.nismoparts.com ... Nismo stands for Nissan motorsports.. Its the nissan aftermarket performance parts.....redmanfx wrote:Ha, it seems we all have the same idea about doing our brakes. I have a problem with e-bay and actually winning a bid. Dial up just doesn't do it when all the bids go down in the last minute. Anyone want to bid for me?
So I can get the rotors, braided lines and Hawk pads from Hitman and still get the Z32 brakes? NISMO studs and 1/2 inch spacers? Never heard of them. NISMO is a brand name right?
Squeefoo where can I order these studs and spacers from tomorrow?
red
It is hard to follow... The reason I brought it out is because this is a very isolated event... RARELY do discussions like this occur, and i say that in all seriousness.....maxnix wrote:Thanks for the quote, but can't make heads or tails of it.
I do wonder why all that is there and not on the board. Kind of like a board within a board. Thanks for bringing it out. Now if there is just something factual there.
If the Z32 calipers are being used with a whole range of differently sized rotors, then the swept area is not what it should be on the larger rotors. While this may be an acceptable compromise on a lighter car, I am not so sure it is desirable on the G50. Anyway, it is still towards the end of the year before I do anything, so the experience of others will be interesting.
Info from SPL's website wrote:Larger brake rotors, even with stock calipers, can provide a signicant improvement in braking over stock rotors. The larger diameter moves the caliper further from the center of the hub, which gives the caliper more leverage thus increasing brake torque (with the same pedal pressure and pad friction). The larger rotors also have more thermal mass, which reduces brake fade. The big brake rotor upgrade is a very cost effective upgrade that provides real improvements to braking.
We offer a 1-piece slotted or 2-piece (floating aluminum hat) slotted 12.8" rotor from Project Mu designed for the Skyline GT-R (R33/R34) with brackets for relocating the stock 4 piston calipers. Brackets are CNC machined from 6061 billet aluminum with heli-coil inserts.
Note: 30mm calipers required, kit does not work with early 90 model 28mm calipers. 17" wheels are required for clearance. This kit has the same offsets as stock brakes, so the kit will fit with any 17" or larger wheels that fit with stock brakes.
Shown below: 2-piece kit with blank rotors (slotted rotors are standard, blank rotors can be special ordered) inside 17" wheels
Paint them Golden, to match the pinstripe and for reasons obvious to mostredmanfx wrote:You would think I should know what NISMO was since I've been here for a while! I guess now I do. I'm ordering from Hitman in just a few minutes. I'll compare NISMO and Midway's prices for the studs and spacers.
Before you put the Calipers on your car you should paint them Bright yellow, so they show through your wheels.
red
