evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sat Aug 12, 2006 5:36 am
I've no got any personel experience with the remapped stock ECU's but I believe you can remap it to work with whatever flow injectors you want so long as they are a minimal size, and the 555's should get you to about 600crank hp and thats measured with minimal fuel pressure, I've also heard when you get into the really big injectors that the orifice is kinda big and that the duty cycle is so low at low rpm's that they can't form a good spray pattern, also it seems most people are keeping with the 555's and it's a tried and true setup
