originalsin »
https://forums.nicoclub.com/originalsin-u14941.html
Fri Feb 25, 2005 10:47 am
set a power goal in HP, not 14psi, psi isent wat makes a hg go, its the hp. set a goal of like 250hp to the wheels er something, running an aftermarket headgasket would be nice insurance but with good tuning a fresh oem headgasket would hold up fine, like dee always says, the key is have enough fuel which would will have with the 450's walbro and id recogmend a FPR, and you should be able to tune it easy enough with an SAFC II and yes the turbo will go right in, unless its off the earlier sr's i belive, it would need to be reclocked (im taking this info from a recent post i read here, i plan on learning more about it too)
