808customz »
https://forums.nicoclub.com/808customz-u71953.html
Mon Feb 11, 2008 7:37 pm
i've been reading here on the forums for quite a while and finally decided to write. i was originally gonna go KA24det untill i got a bargain of a lifetime, nothing i wont pass up. i got a redtop s13 sr20det for $150, yes...$150, i got the complete longblock, including dump and down pipe, intake pipe, ECU, upgraded coilpacks, harness, and the dohc PS lines from the dohc car. mine is the sohc ka. the only catch is i gotta find a transmission. the turbo has minimal shaft play so i'm gonna be upgrading to a gt28r, i'm sure its a direct bolt on to the log mani for the t25. (please correct me if i'm wrong). the person i got it from said that the pistons etc were cleaned up , but i dont know if i should believe, i'm thinkin of using eagle rods and arias pistons, or some sort of rod/piston combo. should i replace the water pump also? what are your suggestions? i cant reacall everything ive read, so please direct me to the correct link if it has already been covered. and the last question is how much power will i be looking at with 14lbs on my setup? so i can get the right FMIC. thanks in advance and sorry if this post is long
